Firm feel UCA
Bruceynz
South Island New Zealand
Hi Guy's
Tonight I finished installing the ff UCA, very easy and straight forward, takes about 30 mins a side. Longest part of the job is getting the pivot bar out the old UCA. Many thanks to Dennis at ff, real helpful!!
Next the alloy body mounts to go in, anyone got any tips?
Volare4life
Yep leave the car on the ground, break the 4 bolts loose, use a engine hoist and a strap with hooks at both ends at the edge of your bumper lip and slowly and gently raise the body up till you see it coming up then pull all four bolts and when it's up and off the rubber mounts, once there is enough clearence, pop out the old bushing pop in the aluminium biscuit and start the bolt back in the hole, do them one at a time, your only going to get so much room to work because the frame rails will hit the upper control arms, also be sure you can slack your brake lines, or your gonna bend the hard lines, also your radiator hoses may have to be disconnected, idk just look for things that might break or bend if you separate the body from the k frame
