My imp
I have a set of 360 heads with a casting#4071051, & was wondering if they have any potential. I also have a like new set of stock replacement 2.02/1.60 valves. These heads were redone, but have been sitting around for years. I would at least clean, lap, & replace the seals before install. So if I go that far, I might as well port match the heads. The heads on my 360 are #4072596, which I read are the better heads. Should I just do a quicky clean up on 051's & put the big valves in the 596's? Or do up the 051's with the big valves? The previous owner purchased a 360 long block & had it installed. Thanks, Larry
