FOR SALE 4 - Mopar 1 & 2 Barrel carbs.
Markt
New Member
4 - Mopar 1 & 2 barrel carbs as follows:
All linkages on all carbs move freely. All are for automatic transmissions. All non lean burn. All are plus shipping cost from 18403.
1-Carter BBD 6150S (3501/08) 2 Barrel. Off a 72 Dodge 318. W/choke thermostat. No choke pull off. Might needs a rebuild. $60. Neg.
1-Holley 1920 (12R-3106) 1 Barrel. Off a mid 60's 225 Dodge. No choke thermostat. Choke pull off works. Absolutely needs a rebuild. $50. Neg.
1-Holley 2245 (R6731A) 2 Barrel. Off a 74 360 Plymouth (Pretty sure). No choke thermostat. Choke pull off doesn't hold. Definitely needs a rebuild. $75. Neg.
1-Holley 2245 (R7644A) 2 Barrel. Off a 360. Model??? W/ electric assist choke thermostat. Choke pull off doesn't hold. Might need a rebuild. $75. Neg.
I thought I might help. No, I’m not in the market.
1972 318 Automatic (all cars/trucks). Dodge p/n is 3614108
The numbers listed are not pulling up, so no help here. My 1920 Holley numbers (in 1965) jump from R3060 to R3149.
1974 B or C-Body 360 automatic. Dodge p/n is 3751431
1974 pickup Not sure if for 360 or 400 - but those are only two (Dodge) engines that used the Holley 2245.
Markt
New Member
Hi Bud,
I appreciate the feedback. The numbers i took off the bodys of the carbs.
The Carter I'm 99% certain was off a 72 318 Charger, long gone.
The 1 barrel I'm 95% certain was off a 66 225 Coronet, long gone.
The 1st Holley 2 barrel I'm about 90% certain was off a 74 Plymouth Satellite (Road Runner) 360, long gone. That part number, 3751431 is the exact number on the front.
The last one doesn't have a part number on it. I thought it was either off a 75 Fury 360 or 75 Cordoba 360, both long gone. Never owned anything w/a 400. I looked up the number also and it comes back to a 74 Dodge pickup. I have a built up 72 Power Wagon and a Ram, fuel injected. Had a 79, 84 and 89 pickup. Never a 74.
