The actuator (being held) resides in the pink circle. The Radio attachment ear is shown by yellow arrow. Between the yellow arrow and pink circle, there is a triangle/pyramid shaped a/c duct that needs pulled out (only held in by friction) and a piece of insulation (for noise).
Almost all the SATC actuators I come across are “stuck” in one position, usually mid-position. You need the door fully in one direction for A/C (no hot air, which is counterproductive to A/C) and the other direction (or mid-position) for heater operation.
All FMJ’s with A/C, the heater core is always “hot”, except for when Max-A/C is on (or off). You regulate the temperature via the temperature door (blend-air door) via cable or SATC servo. I prefer the heater core to only open when I want it to be (ie, when its cold out). The hot water valve (under-hood) allows hot coolant access through the heater core full time (again, except when Max-A/C is on, or system is off).
If you can get a servo taken apart (not easy to do) – it is harder to get it set to position without a lot of trial and error.
I had run out of time to download pictures, on Friday.
The air door (inside of the evaporator case) is the same for SATC or normal A/C. The round rod is threaded and has a “D” shape to it at the top. There is a place for a “quick connect” for the cable on the evaporator case (and a similar one on A/C control head).
A picture of evaporator case/cable connection. The “Blend-Air Door Crank” is a simple piece of metal about 2 inches long (my guess). The side with nut is “D” shaped with a shoulder and is threaded (1/4” thread). Drilling out a “D” shaped hole would be the only hard part. This same part is used on all non-SATC FMJ’s, and practically all Chrysler cars/trucks made in ’70-80’s. Finding the lever is not too hard to do.
The “self-adjusting clip” usually comes with the cable.
93 Dodge Ram a/c heater control cable OEM Cummins 1st Gen. Mopar W250 80-93 | eBay
This cable will work – but will be longer than you need. There should be used cables available from our other members here, as well. I have seen red, white and yellow clips – so don’t worry about the clip color. 40-year-old clips are not that strong so use some patience. If a clip breaks, you can use a screw or a zip-tie to hold cable in place.
This one is for a Van but might work.
The early F-body cable used the same attaching clip on control head but used a screw-on flat-pad on the part that attaches to the evaporator case. That cable will work as well, but just need to get creative on how to attach it to evaporator.
The control head:
The lever the cable attaches to is a bit different. The SATC head lever doesn't have a tab for cable to go into.
The lever is not hard to find and to change. I would find an non-SATC control head and use it or transfer the lever over.
The SATC control heads have numbers on it (just below the lever):
The head on my Fifth Ave had a silver face-plate, so I reused it, after changing the lever.
