The only places you will find the differential codes will be on the build sheet (not seen very often on FMJ cars), the window stickers and on new car order sheets.
a build sheet
The differential codes
will not be on the fender tag or placed anywhere else on car, that I’m aware of.
Starting in mid or early ‘90’s, Chrysler started to stamp a part number and date code on outside of differentials (trucks, vans and Jeeps) – which made it easier to identify ratios, but the only way to know on most FMJ’s is to pull the inspection cover and look at stampings on ring gear.
Blue arrow is part number, red circle is gear ratio and white line is manufacture date.
Note: it is a very good idea to change the differential fluid every 30k miles, anyway.
Differential codes (sales codes) for FMJ's I’m aware of are:
D51 2.71/2.76 ratio
D52 2.93/2.94 ratio
D53 3.21/3.23 ratio
D55 2.45/2.47 ratio
D56 3.54/3.55 ratio (special order)
D5? 2.21 ratio (D58, I think - can't read my writing).
D81 7¼” differential
D82 8¼” differential
D91 limited slip
