MiradaCMX80
Well....I have my little 318 running good, and have been driving the car a lot. Meanwhile, one of my friends is spending my money quickly. I have two 360 Magnum truck engines coming to me for dirt cheap. One is a 96, the other a 2001. I also have a new in box set of Hooker headers that fit my car, again, dirt cheap. We have decided to go ahead and build one nice 360 Mag out of the 2 and put it in the car whenever it's done. I'll keep the 318 in storage, complete.
I've already decided on a 3.55 sure grip rear end over the winter time. I'll keep driving the 318 on that until the Magnum is built. Now I'm thinking about what to do for the Mag. The heads will be the first thing checked to see if they're any good. If they're not, I have been looking at the EQ Magnum heads. Then the short block. As I understand it, a stock Magnum short block is 9:1 compression, and is more than capable of doing what I want it to do.
My questions have to do with roller cam selection, and intake/carburetor. Would the stock FI cam be ok for carb use? Some folks are telling me to tighten the lobe separation up a little to run better with a carb. I really don't understand how that works. Others said "It's fine, slap a carb on it and go." A smooth idle or a slight bit of chop, doesnt matter to me. A good matched combo does. It'd be nice to reuse the Magnum valvetrain without any fancy pushrods or rockers, but I'm open to suggestions. The intake doesn't seem to hard to figure out...EQ heads can be had with an LA pattern to expand the selection, but I'd like to hear what you guys like to use. Carb selection too...CFM, Holley, Demon, or Edelbrock.
I'm looking for a step above stock, I suppose. A nice street combo. 4 barrel Magnum 360 with headers, dual exhaust, A998 worked over a bit, lock up retained if feasible and a matched TC. 3.55 axle with my 27 inch Radial T/A's. Don't need to turn 8000 RPM...5000-6000 would be fine. It appears that even a stock cam Magnum can hit 300hp easy (The old MP Magnum 300 crate engine comes to mind.)
I also plan to dress the engine as an LA with the LA valve covers, timing cover, water pump and V-belt drive. I want to make people think when I open the hood
Looking forward to your advice, lots of knowledgeable people here.
