Mirada with Cabrio top - can it be .....
J Body General Discussion
  1. 76ASPEN-R/T
    76ASPEN-R/T New Member
    Mar 18, 2011
    Lehigh Valley, PA
    New to the J body. I am on the Abody board (FABO) as 68cuda/6vert. My first car (over 25 yrs ago) was an Aspen R/T thus the name. I am looking into a Mirada. It has a Psuedo Cabrio conv top. This top gives the car the appearance of a convertible and covers where the opera window are normally on the car. Can the cabrio top be removed? What problems am I likely to encounter? Would I be better off leaving the cabrio on and if so - how readily available or easily can a new top be installed? Thanks
  2. MiradaMegacab
    MiradaMegacab Well-Known Member
    1,362
    295
    Long Island NY
    Whats your location?
    Removing the fiberglass cap is simple. The factory body seams where the quarter panel meets the roof most often arent finished. The holes in the q-panels and rear panen between the window and trunk will have to be welded or filled. Also there is metal strips riveted just above the windshield that will need to be filled.
    The interior plastic covering the opera windows can be removed easily. Exterior oprea trim is needed, as is rear window trim. The rear window interior trim is also different, smaller in non sim-con tops.
    I am removing a sim-con top this weekend and can text you picks.
    I had the vinyl replaced on one Mirada years ago for 400 bucks.
  3. Mroldart2u
    Mroldart2u Well-Known Member
    262
    May 4, 2011
    Amarillo,Tx
    Welcome aboard... Now that your question was answered, the next question would be how many of these cars were built and how many have been left as they should be? Might be worth more to leave it as is, and not 'undo' a factory option.... M2C
    PS Pics dang it....
  4. Yellowdart69
    Yellowdart69 Well-Known Member
    181
    20
    Apr 26, 2011
    Toronto, Ontario
    FYI - I have an 82 Cordoba with the half vinyl top. When it was removed, to be re-done, I discovered it had the glass "opera " windows in place, hidden beneath the top.
  5. furyfrank
    furyfrank Well-Known Member
    256
    Jun 27, 2011
    Nothing unusual for chrysler if you look at the 82 to 89 fifthave they still have the glass in the back windows under the vinyl roof.
  6. 76ASPEN-R/T
    Mar 18, 2011
    Lehigh Valley, PA
    That is the big question. How many came with the faux Cabrio top?
  7. MiradaMegacab
    1,362
    295
    Long Island NY
    Triple digit speeds will remove the fiberglass shell too.:laughing4:
    I had a Mirada with a 518 OD trans, 2.76 geared 8 3/4 rear and a wild 318 running 6 PSI of boost from a Roots blower. While "playing" with a mustang I heard this God awfull noise. Looked at my gauges, had oil press- blower didnt eat a belt as I was still making boost- tach was over 6 grand and still pulling strong. I look in the rear view mirror,the mustangs flashing lights are a distant sight and I see "something" tumbling around in a low earth orbit. Turns out the conv top must have lifted slightly. Causing air to get between the roof and conv top. Poof pow suprise- holy dissapearing conv tops, Batman! Obviously I never went back to retrive it. A strip of Gaffers tape across the windshield acts as an air foil to prevent this.
  8. Buck Atwater
    Buck Atwater Well-Known Member
    50
    13
    Jul 16, 2012
    St. john's NL
    If you remove the cabrio top are the clips to attach the chrome trim around the windows there or do they have to be added?
  9. MiradaMegacab
    1,362
    295
    Long Island NY
    No clips around the rear window, they arent there.
    The trim for the opera window has integral clips on the trim itself. The trim is not installed under the fiberglass cap.
  10. Buck Atwater
    50
    13
    Jul 16, 2012
    St. john's NL
    I ask because my '80 Mirada is getting very rusty on the frame rails. I found a clean '81 that was used as parts car. The cabrio top was already removed, and I could see factory body filler was never finished where the quarters meet the roof. I forgot to check to see if any of the mounting clips were there but I assumed they weren't anyways.
    I'm guessing it would be a lot of work to try to cut the clips off and transfer them to the other car?
  11. jasperjacko
    jasperjacko Well-Known Member
    1,236
    118
    Dec 4, 2011
    The "clips" are an intragal part of the trim that bends inside to retain the trim. I have a complete maroon interior carpet to headliner minus the dash available. column shift, split bench power seat,etc.
  12. MiradaMegacab
    1,362
    295
    Long Island NY
    How much you want for the front red seatbelts?
Loading...
