I recently purchaced a small block moroso 8 quart oil center sump and was just wondering how many other people are using them on their f bodies and if there is any fitting issues.
Yes i do know the 360 has larger mains then the rest of the small blocks. Im building a 408 stroker for it. Thank you for letting me know it will fit i was a little worried about the steering linkage hitting but you would know better then me.
You'll notice a small dimple in the pan, it's for clearing the idler arm. The size of the mains has nothing to do with oil pan fitting. The rear seal area on a 360 is smaller than the other three. If your purchasing used, check. Personal experience.
