Need this lens!
SharkHead
Polk County FL
1989 5th Avenue - see the photo for the lens, it goes in the upper console for extra courtesy lights that only the 89 and some late 88s had, does this lens possibly cross over to other Chrysler or Mopar models? If anyone has a part number or access to the part for this please advise!
Thx,
Ben III
All 88/89s had the overhead console as part of the better trim package.
Yes, minivans around those years have a longer version of the same console. I don't know if the fwd cars had similar ones too.
SharkHead
Polk County FL
Thank you, that is great information! While you guys are hot on the info does anyone know what triggers the mechanism to make the vanity mirror light up, mine appears to be in good shape but doesn't light up and I have no idea what makes it go!
On most vanity mirrors with an automatic light, there's a switch inside the mirror cover, so when you open the cover, the light comes on. The most common cause of it not working, that I've run across over the years is, the wires break at the visor pivot where they enter the visor.
DCAspen
ct.
Reread your thread,Can you get some pictures of what you need,I have 2 complete overhead consoles
SharkHead
Polk County FL
Need a lens for the courtesy light--not sure which one I will let you know--would love to chat about the temp display as well -863-409-9054 - - do you need a pic of the entire console?
DCAspen
ct.
I have some lights and whole temp display I can pull out on Monday.
SharkHead
Polk County FL
In regards to my dome light issue, the plug next to the parking brake is plugged-in, has power which is shown by all of the other courtesy lights operating, if I unplug it they go off, but I still have no dome light which if I'm not mistaken should operate in conjunction with the rest of the door courtesy lights. Which wire is the positive the pink or the yellow?
DCAspen
ct.
Burned out bulb?On and off button?Bad switch?Bad circuit board?Does the digital display work?
SharkHead
Polk County FL
Both lights work, switches for the lights also work, I just need the one driver side lens, the digital display apparently does not work, is it fixable or replaceable?
It depends on what's wrong with it. First thing to do is take the overhead console down and see if the display is getting power.
There's screws inside those light covers and one of the doors.
