New Clutch- How much $ should be spent on a new clutch set?
greymouser7
31547 off of I-95 near I-10
Should I get the $400 one?
an $800 dollar one?
or the $100-250 dollar ones?
3600lb F body, 3.21 gears, 360 for now, 408 later
i am going to cannex the street or race question by saying that I plan on beating the snot out of the car as if i stole it in the chase scene of a B-flic movie
how long can they last? I will be shifting USING the clutch, not without.
greymouser7
http://www.ebay.com/itm/New-Borg-Be...r_Truck_Parts_Accessories&hash=item3cf510fb1a
New Borg & Beck Clutch 23-Spline 10.5" Disc Pressure Plate Dodge Plymouth Mopar
One new stock replacement Borg and Beck style 3-finger Clutch Kit Organic for 1" Diameter Shaft 23-Spline 10.5" Diameter Disc for Dodge Plymouth Chrysler New process A833 4-speed manual transmission. Includes Clutch disc ,pressure plate, pilot bushing , instructions and installation tool. Throwout bearing not included.
greymouser7
http://www.summitracing.com/parts/ctf-df269675
Centerforce Dual Friction Clutches DF269675 $400.95
Centerforce Dual Friction clutches generate up to a 90 percent increase in holding capacity over stock systems. These clutch-and-disc sets are designed for engines producing high horsepower and big torque outputs. Perfect for 4WD vehicles, all Centerforce clutch systems provide smooth engagement and light pedal pressure without compromising high performance.
greymouser7
http://www.summitracing.com/parts/ram-75-2330
RAM Force 9.5 Twin-Plate Clutch Kits 75-2330 $974.97 Clutch Kit, Dual Disc, Organic, 1 in.- 23-Spline, 9.5 in. Disc, Billet Aluminum Flywheel, Mopar, Kit
These RAM Force 9.5 clutch kits are ideal entry-level dual disc clutches for street use. With a torque capacity of up to roughly 800 ft.-lbs. and moderate clamp pressure, they will handle small blower or turbo installations and provide a light pedal effort similar to the stock clutch. The floater plate is driven from three sets of straps that eliminate any floater plate rattle at idle. The top clutch disc features a sprung hub assembly that absorbs the initial engagement of the clutch and reduces the chance of chatter on takeoff. These clutches are compatible with factory hydraulic release mechanisms, except as noted in the application guide. They are compatible with all factory master cylinder systems when used in conjunction with a RAM hydraulic release bearing.
greymouser7
Mopar Performance Musclecar Clutch Discs P4529137 $122.97 http://www.summitracing.com/parts/dcc-4529137
Mopar Performance
Manufacturer's Part Number:p4529137
Part Type:Clutch Discs
Product Line:Mopar Performance Musclecar Clutch Discs
Summit Racing Part Number:DCC-4529137
Input Spline Quantity:23
Input Shaft Diameter:1.000 in.
Disc Diameter (in):11.000 in.
Disc Material:Organic
Disc Style:Full face, sprung hub
Quantity:Sold individually.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
These Mopar musclecar clutch discs are available for a variety of V8 musclecars. They are designed for use with Mopar pressure plates
greymouser7
McLeod StreetPro Clutch Kits 75109 $182.86 http://www.summitracing.com/parts/mcl-75109
McLeod Racing
Manufacturer's Part Number:75109
Part Type:Clutch Kits
Product Line:McLeod StreetPro Clutch Kits
Summit Racing Part Number:MCL-75109
Disc Diameter (in):10.500 in.
Disc Diameter (mm):267mm
Disc Style:Sprung hub
Pressure Plate Style:Diaphragm
Throwout Bearing Included:Yes
Alignment Tool Included:Yes
Pilot Bushing Included:No
Flywheel Included:No
Counterweight Assist:No
Mounting Hardware Included:No
Quantity:Sold as a kit.
McLeod StreetPro clutch kits are excellent performance clutches for street enthusiasts. StreetPro clutches are ideal for use with basic engine modifications, including cold-air intakes, exhaust upgrades, and engine management programming. StreetPro clutches provide slightly heavier pedal effort with increased holding capacity, making them excellent factory replacement performance clutches.
Additional features include:
* Bolt to stock flywheels
* Handle up to 350 hp
* Organic disc facing for smooth engagement with excellent release qualities
* Kits include a pressure plate, disc, throwout bearing (unless specified otherwise), and alignment tool
greymouser7
Centerforce Dual Friction Clutches DF269739 $467.95 http://www.summitracing.com/parts/ctf-df269739
Centerforce
Manufacturer's Part Number:DF269739
Product Line:Centerforce Dual Friction Clutches
Summit Racing Part Number:CTF-DF269739
UPC:788442017076
Disc Diameter (in):10.400 in.
Disc Diameter (mm):264mm
Disc Material:Organic/Carbon composite
Throwout Bearing Included:No
Alignment Tool Included:No
Counterweight Assist:Yes
greymouser7
Is this the truck clutch? 11inch?
Centerforce Dual Friction Clutches DF070800 $394.95 http://www.summitracing.com/parts/ctf-df070800
Manufacturer's Part Number:DF070800
Summit Racing Part Number:CTF-DF070800
UPC:788442016284
Disc Diameter (mm):279mm
Notes:Must be used with 143 tooth flywheel (big block??) with 11 inch pressure plate bolt pattern. Not compatible with 10.5 inch or 10.95 inch pressure plate bolt patterns.
________________________________________________________________________________________________________________________________________
http://www.summitracing.com/parts/mcl-75108 $230.00 http://www.summitracing.com/parts/mcl-75108
Manufacturer's Part Number:75108
Summit Racing Part Number:MCL-75108
greymouser7
Zoom 30000 Series Clutches 30027 $277.97 http://www.summitracing.com/parts/zzz-30027
Zoom Performance Products
Manufacturer's Part Number:30027
Product Line:Zoom 30000 Series Clutches
Summit Racing Part Number:ZZZ-30027
Pilot Bushing Included:Yes
These 30000 Series clutches from Zoom are designed for 60's and 70's American muscle cars. These sets include higher clamp load Zoom assemblies and organic clutch discs (except where noted) with high burst strength organic facings. They also come complete with release bearing, pilot bearing/bushing and alignment tool.
Features include:
* 20% to 60% increase in torque capacity over a stock clutch
* Complete 5 piece sets include everything needed to do the job right
* Premium, high burst strength organic facings
* Higher clamp load cover assemblies with Zoom anti-rust finish
* Specifically for '60's & '70's American muscle cars with mechanical linkages
greymouser7
McLeod Super StreetPro Clutch Kits 75209 $411.42 http://www.summitracing.com/parts/mcl-75209
McLeod Racing
Manufacturer's Part Number:75209
Product Line:McLeod Super StreetPro Clutch Kits
Summit Racing Part Number:MCL-75209
Disc Material:Organic/Ceramic
McLeod Super StreetPro clutch kits are great Street/Strip performance clutches. Super StreetPro clutches are perfect for use with moderate engine modifications, including intake and exhaust upgrades, camshaft and cylinder head work, and engine management programming. Super StreetPro clutches provide a heavier pedal effort than stock, along with improved holding capacity, making these excellent high performance replacement clutches.
* SFI-approved assembly
* Handle up to 500 hp
* Dual-faced organic and ceramic disc for smooth engagement with exceptional holding capacity
greymouser7
RAM Muscle Car Clutch Sets 92766 $265.97 http://www.summitracing.com/parts/ram-92766
RAM Automotive
Manufacturer's Part Number:92766
Product Line:RAM Muscle Car Clutch Sets
Summit Racing Part Number:RAM-92766
UPC:809009362108
Pressure Plate Style:Borg and Beck
Throwout Bearing Style:Standard
Ram Muscle Car clutch sets are ideal for vehicles with bolt-on mods and musclecar restorations where drivability is the most important factor. Muscle Car series clutch sets utilize pressure plates with increased clamping loads, plus clutch discs with an organic friction material, for smooth engagement and drivability.
greymouser7
Hays Street/Strip Clutch Kits 85-311 $358.97 http://www.summitracing.com/parts/hay-85-311
Manufacturer's Part Number:85-311
Product Line:Hays Street/Strip Clutch Kits
Summit Racing Part Number:HAY-85-311
UPC:084041853115
Hays Street/Strip clutch kits are engineered and built as matched assemblies, using only top-quality new parts, to deliver maximum reliability and durability, as well as long-term dependability. They're available in both diaphragm and Borg & Beck styles, with sprung-hub clutch discs that have organic linings. Applications are available to fit a variety of cars and trucks aimed at street or street-and-strip use. The kits come complete with a pressure plate, clutch disc, throwout bearing, and clutch-alignment tool (most kits). A pilot bushing is not included.
greymouser7
What is this used for?: PRO-SERIES BILLET CLUTCH 1500-HP HEMI 4-SPEED 1-3/16 x 18; 130T FLY, 6 BOLT CRNK
http://www.ebay.com/itm/PRO-SERIES-...r_Truck_Parts_Accessories&hash=item1e6e4a5841
Price: US $2,395.00
McLeod Racing / Boninfante
Other Part Number: Aluminum Flywheel ARP Hardware 440 Manufacturer Part Number:
43461-00-05
Surface Finish: Red Anodized Interchange Part Number: MoPar Chrysler Plymouth Dodge 318,340,360,383,400
1500-HP Rated Drag Race Clutch - Single Disc
Dual / Triple Disc Available Up to 3000-HP
Pro Series I - Aluminum Flywheel Integrated w/ Clutch Assembly
McLeod Racing and Boninfante Friction have joined forces to create the ultimate 10” street clutch for the ultra-high horsepower cars from 800 to 1,500 horsepower. This is a fully CNC-machined 6061 T-6 aluminum construction utilizing the latest in high performance drag racing technology.
Easily handles cars with 800-1,500 horsepower in a single disc configuration.
Fully red anodized 6061 T-6 Billet Aluminum construction
Fully adjustable spring pressure, adjustable stands and counter-weighted levers
Choice of sintered iron or metallic discs
Complete, includes ARP hardware, pre-set height gauge and weight kit
Street or Strip Capability.
Application: DODGE,PLYMOUTH 1961-1978 V8 318,330,340,360,383,400,440 ; 130T R/G 0BAL 6-BOLT CRANK 1-3/16 x 18 INPUT
PPW, OVER 15 YEARS ON EBAY. WE ARE A.S.E CERTIFIED TECHNICIANS. FREE SUPPORT 9AM-5PM PACIFIC TIME (619)261-8565
