shadango
ANy advice on replacing the engine mounts on a slant 6, 1980 F body?
The left one on our newly acquired Volare is bad....engine rocks pretty good if in drive and you hit it hard....
So I went to Rock Auto and it looks like you can actually just buy the rubber insert or the whole unit?
No point replacing the brackets I guess if I can just replace the rubber inserts but wanted to check in here for some advice/experienced info.....
Also -- looks like the left side (drivers) is easy enough to get to...but the passenger side...yikes.....any tips here would be appreciated as well!
Thanks all!
Thanks all!
