rustyratrod
Any time you remove. 090 from the deck or head combination you will need a custom length pushrods. With that much removed the pushrods will be too long and the rockers will not be pushing on the center of the valve stem.
Well somebody better tell me, because I just assembled this with a head that was cut .155" and the original pushrods fit just fine. Pushrod length has squat to do with where the rockers engage the valve stem. Nothing. Nada. Zilch. Zero. As long as they are not too long and will FIT between the rocker and lifter and will adjust to the correct lash, they do not affect geometry one iota.
Now, I have a factory closed chamber head I am installing 318 valves in. THAT affects geometry, because of the longer valve stems.
So I will have to get with Mike at B3 Racing Engines and get some custom shims from him to relocate the rocker shaft. Once that's done, it will be fine.
