2) How do you make sure you have very little play at the center ? Can it be adjusted ?
This is what i mentioned in my previous post, tightening the allen bolt on top of the steering box. There's a bunch of DIY's online about this.
Like M_Body_Coupe says, you want to tighten the adjuster enough to take out some play, but not so tight so the steering binds at center position.
I tried a procedure I found online which includes measuring the torque needed rotating the steering wheel through center position, wheels in the air, engine off. This was impossible to get right, with my tools/torque wrench anyway.
Ended up tighten the bolt in small steps while wiggling the pitmarm arm until I felt no play in it.
Don't go overboard tightening the adjuster. A little too tight and the steering binds, very tight you may ruin the teeth on the shaft(s).
