I treated the inside floor pans with Por-15 with a brush and it worked fairly well, however when it comes to underneath the car i cant imagine brushing is going to get at all the areas. Can anyone recommend a product in a spray can for under the vehicle? I saw that zero rust has some in a can, also what about the eastwoods rust products? I saw that rust-oleum also has an epoxy paint for appliances, i wonder if that would work for under the vehicle after some POR-15 metal prep is applied? I believe the POR-15 metal prep is a rust converter aswell as an etching agent to help paint stick, so regardless of the paint under the car i will likely still use metal prep.
