WANTED volare manual brake firewall plate
I have one - but I also plan on using it, soon.
There is a difference between the '76-77 and the '79-89 version. The difference is the '76-77 uses a 4-bolt cast iron master cylinder and the other version uses the 2-bolt aluminum master cylinder.
It might be an idea to make your own bracket - if you can't find one.
I can take measurements of mine - if wanted (which is off of an '79).
