Toying with the idea of a magnum swap
I said;
AFAIK; Magnum truck engine mounts are different from LA engine car mounts.
That might slow you down some.
Assuming you already have a 318;
the power difference in the 5.2, over the 318, is in the compression ratio, the better heads, and the bigger cam. The short blocks are similar enough that you could call them the same except your 318 already fits in your car.
If you were to pump up the Scr on your 318 and install the Magnum heads and upcam, then you would have the same or similar output as the Magnum. You just wouldn't get the roller cam, which IMO, in NOT a big deal.
and then I talked about gears and stuff ..................
but thank you for this; I wasn't sure about his 83
  • All Magnum motors have the LA mounting ears cast into the block, for the entire production run.
Which is why I said this
"AFAIK; Magnum truck engine mounts are different from LA engine car mounts.
That might slow you down some."
So now; AFAIK, all Magnum motors have the LA mounting ears cast into the block, for the entire production run. Good to know
LSM360
Melbourne, Florida
It's a good swap. I've done two M body Magnum swaps, both MP crate engine 360/300hp (underrated). Gobs of torque. Mine were carburated. The OD trans and EFI at the same time would be a very nice addition. I stayed with a 727 and Holley 750 myself. My current 360 is really built. 410 cubes, FiTech, and 528 lb/ft torque on engine dyno. But some day I'd like to have another Magnum engine. Maybe in my truck (or modern Hemi like Mike mentioned).
