77 Cordoba - Craigslist
1977 Chyrsler Cordoba
Details:
400 Big Block factory four-barrel. Currently with Edelbrock carb.
Currently not running. Motor turns over easily. Was running fine until the ignition switch broke.
Strong runner. No smoke. Not an oil burner. Will run if you fix the ignition switch.
This car is a roller, not running, but is a factory big block Torqueflite.
You tow.
$650
No text or email. Phone calls only in response to this ad.
Contact Dave at show contact info between the hours of 10am and 10pm Oregon time.
Other than its yellow, no shifter in the floor -- seems like a good project. Although I don't know about the rust side of the equation.
JW
Jonnyuma
TOW? How 'bout 10 min with a steering wheel puller and a big socket and DRIVE the thing away... ?
Rust isnt a problem w native OR cars unless they've been on the coast.
When I moved to OR from AZ I lamented the loss of clean southwestern sheetmetal... til I got here and learned what's what.
The only cars w rust here are ones brought in from ID MT, or eastern WA.
It's one of the best kept secrets in the hobby.
Ssshhhh... that's just between you and me.
Recycle that hood and you could make two K cars from it.
jasperjacko
Yep, that's where mine came from. Zero rust, and still had the original exhaust in fabulous condition.
