I'm parting out the car, and have a member that wants the rear window louvers. I don't see any mounting method from either side, does anyone know how to get these off without damaging anything?
There are a few metal tabs that wrap around the window opening. As OldIron mentioned, the 1/4 glass has to be removed first. Then you can CAREFULLY straighten the tabs. They aren't attached to the louver very well, just a couple of heat deformed pegs basically and it's easy to accidentally pull them off, if some aren't already that is.
