mworke
OK, I need some advice and recommendations on header clearance to the power brake booster in an '87 FIfth. Several years ago, I installed headers and 2.5 in duals out the back. At that time I encountered a slight interference with the power brake booster and the drivers side header. To resolve the issue, I enlarged the holes in the fire wall where the brake pedal assembly passed thru allowing me to shift the booster/master assembly away from the header. This has worked great for me up now, but I plan to swap in a 4-speed setup this spring and will have to move the brake assembly back to its original location due to clutch rod/z-bar assembly alignment. So......I am now back to the original problem of booster to header interference. FRUSTRATING!
I read some where that early K-Car boosters will fit. They are smaller diameter and should take care of the issue. Does any one know what year booster will work. Mfg. part number would be great. Thanks...Mike
