So this evening's entertainment was '''''' ta da da da!!! -- drilling holes in the joists so I could pull electric line through in order to add just one more breaker to the breaker box.
Everything currently being stored on the north side of the garage had to be moved.
Ladder up. down. up. down. up. down. til I have all the joists done and the line pulled.
Fish the line into the wall cavity and dropped into the box.
Strip the lines and put the copper wire in - CHECK
put the white wire in -- CHECK
put the black wire in the breaker -- CHECK
put the breaker in the box --- ....... honey -- are u sure you bought the right type of breaker?
yes... its a square D.. you are just not putting it in correctly.
honey -- I'm sure I've got it oriented correctly.
no dear -- if you did, there would be lights on in the greenhouse.
honey -- there is nothing for the breaker to connect to for an outside metal rail -- just plastic.
what?? are you sure. try again.
honey -- I tried both ways and I'm very sure there may be space in the box, but the box doesn't have enough rail for this.
Well crap.
So after much reassurance to the Mister that this is not gonna work... he finally agrees and says lets look at it in the morning.
My vote is to change up how we've done the lights. All the lights are LED and don't draw squat. I don't need a 20 amp breaker for 12 LED's that are never on at the same time or for any length of time.
But then, we've had this discussion before and I was voted off the island ...lol
Looks like Plan B is in play for the weekend.
Well crap.
