Dodge Diplomat Turn Signal
Zeph_L
Green Bay, Wisconsin
The driver’s side turn signal on my 1980 Dodge Diplomat has not been working properly. The passenger side one works just fine, but the driver’s side front signal light does not come on at all. The rear one comes on but does not flash, as does the dash light. Anyone know what the problem may be?
toolmanmike
Super Moderator
Did you check and change the bulb?
A bad bulb would normally cause the right blinker to flash more rapidly than the left. Its either a wiring issue, a turn signal switch, or the flasher itself. I suppose in some odd cases, it could be the socket. I'm betting on the flasher, which is cheap and easy to fix.
A bad ground will cause those sort of signal problems. Bulb problems can also make it do strange things.
I thought that feature was only on modern cars
Its always been the way nornal flashers work. Change in load with burn out bulb makes them go faster or slower. Same reason you used to have to change the flasher to a heavy duty one if you had a trailer connected. And then check the lights regularely because those flashers didn't do anything different when a bulb was out.
AMC Diplomat
NY
Some old cars have a steady on, or a steady off, or a change in flash rate.
If anyone is really curious, and has time to waste, here's a breakdown of how flashers work
AMC Diplomat
NY
I changed the bulb and the flasher. The rear signals and the dash light work now, but the front one does not. It lights up when the running lights are on, but doesn’t when I go to use the turn signal.
Do you have the right kind of bulb up front? Are both the driver turn signal and sidemarker not flashing? They both come on and just stay on?
toolmanmike
Super Moderator
Great video. Thanks for the link.
LSM360
Melbourne, Florida
As Mike wrote, it's often the ground causing an issue on these. Try turning on the signal and wiggling and pushing bulb in and see if it starts working.
armataz
springfield OR.
I would still check if the flasher relay just went out for the side not flashing. if it was the ground, the light generally dont come on at all.
The flasher is the first thing to check.
It all depends on where the bad ground is. I've had far more lights with ground issues that made it do strange things then not work at all.
