Door Window Seals (Oddity)
LyonAdmiral
I know that these things dry out and wear out over time but in my 85' Fifth, I've noticed that the driver side window seal has been the one to tear and slowly shrink now to the point where the top of the window seal is at a quarter of its original length.
The other window seals in the car aren't attributing any type of shrinkage or wear at all. I wish I could keep this thing garaged but I can't. The car has 360 degrees of equal weather exposure so do you think it's just the luck of the draw?
Lastly, is it for these Model M's, are we just SOL when it comes to finding replacement window seals? My local mechanic (who worked on the city fleet of Diplomat's years ago) suggested I go to a local rubber company but they don't want to be bothered for such a small job and I can't say I blame them.
I need seals replaced on all the doors so I've sent off for some catalogs to see if I can find a profile similar enough to work.
My theory on the shrinkage, other than cold water ;), is maybe the drivers seal was made from a different batch of rubber that wasn't made correctly, or something like that?
I've seen it on cars before where the car has multiples of some part and they're all like new except one which is disintegrating for no obvious reason. As you said,,,luck of the draw.
89.Fifth
New York, NY
These are the ones I ordered. Fit was OK. Closest I could find.
Metro Moulded Parts ~ Top Quality Automotive Weatherstripping and Rubber Parts
There's more here, you just have to take good measurements.
That part is rock hard and cracked/broke about 2/3rd up on L/F door on my 5th Ave.
The same part on my wagon is still soft and pliable.
