MoparKidD-4
Took my 5th Avenue in today to get it emissions tested; first test failed CO by a good amount so I talked to the mechanic who sold me the car and he said the problem is with the electronic enrichment solenoid in the carb; for some reason it tends to run rich once it's fully warmed up and in closed-loop mode (still the factory 1988 Electronic Spark Control system). He recommended pulling one of the vacuum lines that goes to ported vacuum to lean it out (air leak) which I did, I also put 4 oz. of Lucas Ethanol Treatment in my tank and filled it with 7 gallons of 91 Premium (I had it about 2/3 full with regular which is 85-octane up here at high altitude). I just took it back now and it failed again but only by 1.6xxx ppm mad:). It's so close to passing I'm thinking of just unhooking another vacuum line or maybe just a bigger line like the PCV but then I have to be careful to hide it because they do a quick underhood inspection at the e-test station... any thoughts?
I would also like to figure out what the base idle ignition timing is but I can't find any information on how to do that properly with this wacky computer BS lol
EDIT: I know the cats are old and probably need to be replaced but my plan is to cut out all the old exhaust and install headers with dual side-exit exhaust and a NEW aftermarket cat on each side which will take time, 2 years is more than enough time to get that stuff on by the time I need another E-test...
