WANTED Front Floor Pan 80 Aspen 2 dr
FMJ Body Parts Wanted
  1. Motorhead80R/T
    Motorhead80R/T Well-Known Member
    65
    Nov 13, 2016
    Marietta, N.Y.
    Contact Seller
    I`m searching for a floor pan for my 80 Aspen, the feet area is rotted on both sides,,Does anyone know if a floor pan from another model would even be close,, I see that AMD has a pan for a 71-74 scamp that measures pretty close, But that would be a 400.00 gamble
  2. 7T8 Custom
    7T8 Custom Well-Known Member
    760
    257
    Oct 17, 2015
    Vancouver, British Columbia
  3. DCAspen
    DCAspen Well-Known Member
    953
    191
    Sep 27, 2011
    ct.
    Jims AZ Parts,I think an 80 floor is different than the 76-79,Jim will confirm this.
  4. Motorhead80R/T
    65
    Nov 13, 2016
    Marietta, N.Y.
    Thanks guys but I already try`d Jims with no luck
  5. AJ/FormS
    AJ/FormS Well-Known Member
    961
    202
    Apr 26, 2016
    The 1980 floor has a bubble raised area for the Cat-convertor, on the passenger side. This puts the one track in a different plane.
    I have no idea, but I suspect an older model floor will go in there, but you'd need the matching seat tracks.
  6. Motorhead80R/T
    65
    Nov 13, 2016
    Marietta, N.Y.
    Aw thank you, I hadn`t thought about that,, But Now I`m wondering if I just used spacers to adjust seat height as I don`t have any cats left on here
  7. AJ/FormS
    961
    202
    Apr 26, 2016
    Let me repeat; IDK if the earlier floor will physically fit...... I only suspect it would.
    If the cat's are gone, ain't coming back, and by law don't have to be there......then I would give it a shot.
    As to the seat;Yes; I shimmed my passenger seat level with a hardwood block. This put it slightly higher than the driver's seat.
