mopops
driver side floor mat wet after using A/C , i am guessing the drains are plugged whats the best way to solve this issue? tks mopops
finally able to take a look ,100plus heat here. couldn't pull it out but got it open must have been close to a quart of juice came out n still draining. tks for the help gjgloverGo under the hood and find the rubber drain elbow. It's on the passenger side of the firewall towards the bottom. Pull the elbow off and either blow compressed air in the drain tube or, CAREFULLY stick a small screwdriver or wire in the tube to dislodge the clog. Also check that the rubber elbow isn't plugged. They are the most common cause of a blockage.
