J Body Wheel Offset
moreada
Hello,
I am curious, when looking for wheels for our cars, what offset or backspacing should I be looking for? Mine is an 83 Mirada. Its a 5x4.5" bolt pattern, IIRC.
Thanks
majo
NE OH
I'm curious about this as well. I've been a member of many forums, and this is one of the hardest questions to get an answer to!
Joe12459
Catskill Mountains, NY
These are low offset wheels. The mounting surface is offset only slightly inward. I usually use 3 3/4" to 4" backspace on an 8 inch wide wheel, with good results. A lot depends on tire size and suspension.
moreada
Thanks. I was looking at wheels and wasnt sure of the offset/backspacing for our car. Maybe they're not even the same thing?
oo is the distance from the wheel mounting surface to the inside flange (not including the metal bead) of the wheel. Offset is the distance from the wheel mounting surface to the exact middle of the wheel width. Same measurement needs to be made, but after that, you need to do some math to find offset.
Backspacing is a lot easier to measure, a straight edge across the rear flange of the wheel, then a perpendicular measurement to the wheel mounting surface. Offset would need to take the same measurement, then calculate the center point of the wheel width and subtract the wheel flange measurement. For our cars, the backspacing will usually be about half the wheel width, and close to zero offset; so for a 15" X7 " wheel, the backspacing will usually be around 3 1/2", give or take a 1/4" or so, and offset will be around 0 give or take a 1/4" or so.
For most stock rear wheel drive cars, the backspacing will be close to half the width of the wheel (close to zero offset). It can vary some for specific reasons. For front wheel drive cars, the backspacing will be more than half of the width of the wheel, and a positive offset (wheel mounting surface will be closer to the visible or outside wheel flange). Flangeless wheels are the result of very high amounts of positive offset/backspacing. The backspacing/offset seems to vary a lot more for front wheel drive cars.
moreada
That's a great rundown. I never knew backspacing as a term and 3.5" offset sounded nuts so I should have seen that as a red flag they'd be two different things. Guess if i stuck it out a bit longer at the wheel and tire shop it'd have been something i had to know haha.
Thanks again.
Miradaman
WV
In case anyone was thinking of trying them, do not use Jeep 10 spoke wheels. They will bolt on, but get caught on the front A- arms. 78 Thunder chicken rims will fit if you grind out the center holes to fit over the bigger Dodge hub.
