Mirada512
Just an out of the blue question. Do any other k members fit the j body. Just wondering before I get to that point and start cutting up the small block k member.
I have the small block k member but going big block. Was wondering if other k members would work. I was at a family gathering and the thought went through my head.Do you mean like the almighty Slant-Six leaning-power-o'-tower???
Yes, that K-frame would fit, if you want to run a V8 you'd need a set of engine mount adapters though.
That I know, just wondering if any other body k frames fit or any aftermarket engine cradles would work.F/M/J all use the same k-member, if that's what you meant(?)
Yup, in that case you can use the very same K-frame, but you need to score a set of the Schumacher () conversion mounts.I have the small block k member but going big block. Was wondering if other k members would work. I was at a family gathering and the thought went through my head.
I’m going to big block. So any 73+ big block k member would fit? Sorry for asking just confused on what you said. Thank you
