Miller trans tools ID
volare 77
Does someone know what these tools are for? I think they are miller trans tools of some type. I want to sell them but I would like to know what they do.
Are there any numbers on them? I see one on the tool with the 2 screws but can't quite make it out. The tool on the right APPEARS to be some sort of forcing tool to install bushings or bearings(?) I see the thrust bearing which is more like a pulley installer. Only a guess.
The other tool, no ideas at all. Are you sure they're for transmissions?
volare 77
After some help and research I found out what they are for. The C3289 is superseded by C3529 which says it is for powerflite and 56 chrysler 3 speed trans. It is used for the servo spring compressor. The C-708 was shown to be for a fluid drive trans for runner hub bushings installation and burnishing.
