Radio connections, electric antenna G22
No problem. That sounds about right.
I need to dig into the wiring myself at some point down the road because my truck has an aftermarket radio i want to put back to stock and I'm sure they've messed with the wiring for that.
Gunnar Schroder
Norway and Sweden
Good to hear from you and I will send you feed-back later when the antenna is in Place. I am positive it will fit. As I see it there is no other solution.
Gunnar Schroder
Norway and Sweden
An unclear scheme I made for my own memory and simplified
It doesn't feed to 2 different fuses like your diagram shows. The X12 20BK/R goes to red wire of the radio which was previously connected to the fuse. Which is where the X12 20R wire now connects.
Gunnar Schroder
Norway and Sweden
Sorry Mike for dropping a clanger. The original red was already connected aleady to fuse 11! I am looking forward to checking it over on wednesday. So the other from the Contol box just connect up with the one already in use?
