76volareman
All A500s were lockup from Day One. The early ones are hydraulic lockup, which is the same as the lockup A904. Neither requires an electrical input to operate. So, just like the A904 and A727 lockup converters, they are quite failure-prone with any kind of power. A OE non-lockup converter cannot be used on them, as the spline count is different between lockup and non-lockup converters. I do believe that some companies offer non-locking converters with the lockup spline, though.And to add the A500 was available with a non lockup converter, it has the 2 pin connector not a 3 pin. Same goes for the A518. They were the early units and very hard to find. You can also change out the front pump and output shaft on either transmissions to convert the lockup to non lockup and run any 904/727 performance converter you want.
