Found one!
aspen77rt
Shelton, WA
It smoothed out the idle even better than the Street Demon. It idles @725rpm. Took it out Sunday and the throttle response was excellent. On par or better than the SD. Test drive went smooth, no hesitations, surging or what have you.
CUSEMIRADA83
Syracuse, New York
I recently purchased a SD. How did you like it? Why did you get rid of it? Also, where did you get that throttle/kickdown bracket? Brand and part number would be nice..The one offered by demon is cheap looking, IMO. Your Mirada sounds good with the TBI...
aspen77rt
Shelton, WA
I recently purchased a SD. How did you like it? Why did you get rid of it? The one offered by demon is cheap looking, IMO
Nothing wrong with the SD. I liked the small primaries/big secondary's. It performed well in street driving. I just wanted an aftermarket EFI on the Mirada.
BPE Torqueflite Kickdown Cable Kit (BPE3350)
Bouchillon Performance Engineering - BPE Racing - BPE Torqueflite Kickdown Cable Kit (BPE3350)
Instructions for the above kit
Bouchillon Performance Engineering - BPE Racing - tqinstructions
aspen77rt
Shelton, WA
Sucks when you put the gas tank filler grommet on backwards.:mad:
Running great though. I will be rigging the cruise cable back up.
What rear gear did these come with? Christ I'm cruising at 60 mph and only turning 2100 rpm at most.
I want 3.73's with a gear vendor's unit.:)
'77's came with either a 2.45, 2.94 or 3.23:1.
2.76:1 was an option on other years (but I don’t think used in ‘77)
There "should" be a tag on one of the inspection cover bolts, and another tag if it is limited slip.
My ‘86 has a 2.24:1 vs a 3.23:1 in my ‘77.
That is one huge difference to the seat of my pants feeling (or lack thereof).
aspen77rt
Shelton, WA
I believe it has the 2.24 the way it cruises. The tag was hard to read. The tires (245/60r14) are only 25.5 inches tall. It cruises like my '77 with a 3.23 and a manual OD trans.
I know the 8.25 I have for it was from a '77 Dippy with 2.45 gears.
aspen77rt
Shelton, WA
Working on the engine bay plumbing. Cut to length Accel 300 spark plug wires. The initial timing is set a 18 degree BDC, and I'm not running a vac advance right now. The previous vid was 10 BDC.
The cruise cable bracket fit right on top of the Bouchillon bracket with a bolt through an existing hole. It's not hooked up right now.
Darth-Car
Ohio
So do your A/C vents all have runny noses that require them to have tissues handy?:)
aspen77rt
Shelton, WA
Dryer sheets, mice hate them.
--- Post updated ---
Added heat shield because I didn't like the Heat soak on the fuel rails on the TB.
And another useless pic of the display
aspen77rt
Shelton, WA
To recap
From this
To this
To this
On the last photo above,
That shiney bent bolt going through the Bouchillon bracket, is what's anchoring the cruise cable bracket. I just have to cut it off after the nut.
***USELESS VIDEO ALERT*****
Boring Sunday drive. Messing around with the gopro. The rattling might be the gopro mount.
aspen77rt
Shelton, WA
Decided to take the Mustang out after I pulled the door panel because the power window took a dump.
Well let's get started.
Have to stop. Thought I had eight poly shackle bushings. Had only four.
