Bruceynz
Hi everyone,
Ok my friend has a pair of J heads with 2.02/1.6 valves, crank, rods, KB piston/rings and a 360 block he was going to rebuild and put into an A body. His planes have changed and I have agreed to buy all his parts and build a 360 for my 83 Cordoba. I have a 904 and 7.25" in it. I have located a 8.25" rear with a 3.21 ratio I will put in. Now I do not know where to start with camshaft selection. I currently have a sum 6900 can that I was going to put in the 318, I want to stick with stock converter so can anyone recomend a cam for a 360 that will work with the big valve heads and will work ok with torque converter.
Sum 6909 Cam specs I have now - 204/214 .421/.444 LSA 112
Thanks
Bruce
Thanks
Bruce
