80 Mirada,
Every 518/500 swap turns out different. Most use either a Ford or GM trans mount. Using a stock floor shifter is out for most people, but Hot Rod made it work in a roadrunner, and I have seen shifters converted to cables. Relays for each solenoid will make them, and your wiring, last longer. There have been number of ways to control the overdrive and/or lock-up. Time delay relays can be uses to get rid of gear pecking if using pressure sensors to control it automatically.
metallicaman0258
Charleston, West By God Virginia
From what I've checked out, Ill keep the 3 speed for now.
A look at the completed under-hood braces.
First attempt at rear mounts for the 1" rear bar. I drilled the sides wrong and had to redrill the mounting holes, the top is notched to fit next to a reinforcement. The brackets I made for the shock plates ended up being tossed in the scrap pile for a set of Firm Feel ones.
The Addco bar is a pain in the butt. I had to clearance the ends of the bar and the control arms. I also had to do some creative grinding to get the end bushings to seat against it.
The front set of springs are a set of low mileage 5 leaf cop car springs that a local yard had on the shelf, they were still crusty. My 4 leaf springs were shot at best.
I made a set of support plates for the front spring hangers, dont mind the odd holes. I then bought the Firm Feel Iso-elimination kit, with sway-bar tabs.
I cut away the dust shields, but left the park brake portion. The center bore needs to be slightly enlarged, I used a grinding stone on a die grinder, and the bolt holes needed a little bit of clean up. this is such an easy swap I recommend it for everyone. The jeep I got this set from was pretty clapped out.
Semi-complete rear, used 3.91 gears with a limited slip, most of the Jeep brake swap, and a 7290 yoke off a 4x4 Dakota, bolted to '85 Diplomat 5 leaf cop springs, with Firm Feel Iso-delete kit and poly bushings.
Rear is mounted with the Addco 1" rear sway-bar, just a few days before going to storage. The first time the Mirada has been on 4 tires since we had moved in almost nine years earlier.
CUSEMIRADA83
Syracuse, New York
I installed the A500 in mine about 10 years ago. Works well...It needs to be rebuilt as it was a junkyard piece that I threw in after my 904 crapped itself...Will be keeping an eye on this thread, for sure.
