Alloy 318 Mopar Block
This month's issue of Mopar Action has a question regarding aluminum LA small blocks in the Tech Questions section. Accord to Rick Ehrenberg, there is somebody who actually offers these. I'm at work, so I can't look it up right now.
Kostas
MiradaMegacab
Long Island NY
Hughes has Ritter aluminum blocks.
Kent Ritter is the person that was written about in the Mopar Action Tech Topics section. The reply from Rick Ehrenberg said that it uses all stock components. Interesting that it is a 4 bolt main block. I don't know that there are many 4 bolt main LA blocks of any type, but I may be speaking from ignorance.
Kostas
80 Aspen RT
Kansas
Kent Ritter used to make KILLER small blocks, and raced NHRA. He ran a look alike to the pro stock car Darrell Alderman drove. Except Kents was a small block. It was a bad assed car.
I haven't heard of him for awhile though.
chmirada
Worcester, Ma.
I'm from the area , i seen that posting several times , I believe it's a Magnum block
greymouser7
31547 off of I-95 near I-10
Kostas
You are correct. The only four bolt main blocks were the R series and maybe a couple of X blocks because Chrysler was crazy. ({ aftermarket blocks}) I am pretty sure that not even the Trans/Am blocks are four bolt.
That one listed in Boston has been listed for a while. It seems this block might be experimental to the Magnum transition and I believe would only have been a few blocks. They make fiber glass 60's Cuda fastback shells now and this would match that light weight theme well.
