Mancini has listings for the conversion mounts but, they say "out of stock". Since they were Schumacher (I assume) mounts, who knows if or when they'll be available again.
Another possibility is to do what I did, before there was such a thing as Schumacher. I cut the k-frame brackets off my good, rust free 6 cyl k-frame and then the brackets off a V-8 K and welded them to mine and used stock spool mounts that came with the 440 (from a '71 Roadrunner). Swapping K's was the 1st choice but out of the dozens of V-8 k's in the salvage yard, there were NONE that didn't have at least one rust hole. (This was back in the late '80's,,,,,in Wisconsin, btw). Worked then and it's still working to this day. Just an idea. I suppose, trying to find a V-8 K to cut the brackets off in the first place is not very easy nowdays, so it's probably a moot point.
