Bruceynz
Hi Guys,
Ok I have some PD-16 cam bearings for an LA. I thought the LA and Magnum were the same but the correct part for the magnun is PD-25, I called Dura Bond and they said that 2 of the bearings in the LA are a little wider, apart from that they are the same. I have a set of LA cam bearings here I was going to put into the magnum, will it be ok to use them(PD-16)?
Thanks
Bruce
Thanks
Bruce
