mopops
1989 360 La roller motor from van, 8-1 compression in 82 mirada 904 trans 373 gears . what cam can i go with to wake this up-no piston change. tks
What are you expecting from a cam-change?car runs real well
crap I forgot360 LA motors went roller cam in 86 or 87
With No Other Changes, you cannot wake up the bottom end with a bigger same type cam, that has a later Ica. The later Ica drops pressure every single time no exceptions. Less pressure means less power.1989 360 La roller motor from van, 8-1 compression in 82 mirada 904 trans 373 gears . what cam can i go with to wake this up-no piston change. tks
