Column ID help please...
dkamp
Terre Haute In.
I have a steering column I was told it was MFR by Saginaw and is from 75-76 Chrysler New Yorker or Large Chrysler, or Eldorado Style
Has anyone actually seen this column on a vehicle?
I'm trying to locate the parts so that I can get the Telescopic feature to work again.
I need the two parts in the Red Circles.
Any info or Part Number will be appreciated.
Thank you !!!
David
It's from the new yorker style you mentioned and maybe Cordoba of that time also. The column itself is probably the same one or close to what GMs with tilt/telescoping had also.
LSM360
Melbourne, Florida
I guess you looked closely for a part number stamped on the column. Definitely looks to be Cordoba or New Yorker 75-78 from the cruise control stalk, horn pad, and shift lever.
dkamp
Terre Haute In.
I have looked in detail for any form of casting number or part number on the column.
If anyone has a 75-78 New Yorker with Tilt can i get pictures of the end of the column that sticks out of the firewall side?
David
kmccabe56
View attachment 48160View attachment 48161
Thank you !!!
David
Because it's a Saginaw column, the parts you need would be common to any car i.e. Cadillac that has a tilt/telescope column. There must be somebody on this site who has the 1978 Pass Car Parts catalog or if all else fails, check a local dealer to see if they still have their catalogs or last resort check out a GM dealer.
