Drivers side front frame rail
Voeltagear
Green Bay, WI
How different are the Abody frame rails to the Fbody? Has anyone compared the 2 side by side? Just asking because the Abody frame rails are readily available.
That’s like putting a front Abody fender on your Fbody, no work unless you hack the hell out of it and then it’s still not going to work!
Voeltagear
Green Bay, WI
Ok. Just thought since the turnaround between the 2 chassis was so fast maybe they used some of the same tooling and the parts might be interchangeable. Especially where they wouldn't be seen. I haven't look real close at the aspen yet. I'll have it home this weekend. I know the driver's side frame rail is no good ahead of the cross frame. Any good sources still in business?
Yes, F/M/J are the same. As you know, a-body isn't even close. Left front subframe rail rot is very common, even on relatively rust free F-body cars. My theory is battery acid fumes getting in at the front, and settling in the lower areas. Just a theory though and may be way off base!
If for some reason any A-body body parts fit your FMJ, then it is more of a fluke than anything else.
\The F-body (later modified to M and J-body) was a clean sheet of paper re-design. They did intend on using some existing mechanical parts (spool type engine mounts, steering gear, spindles, rear differential parts (not width, though) and so on/so forth.
After working on A (or older B)-body dashes, the F and M-body is SO MUCH easier, among other things.
IF A-body body parts would fit FMJ's - that would benefit us by a huge amount.
I like that theory.
Even on older Mopars, the floor pan by the L/F frame rail would rust out way before the passenger side does.
I've seen (and replaced) a bunch of battery trays on Mopars before, as well.
I would have thought if it was the battery that it would happen to other types of cars too. But I don't know what else is different to that one side.
It was mainly the earlier years prone to rusting out there
The reason I bought a battery with a vent tube, which I ran down to the bottom of the car. Also keeps the top of the battery clean, and no terminal corrosion. It makes a huge difference.
Ele115
Tampa FL
GM's did the same thing, maybe worse. With the side post, people usually didn't see it but the battery terminal post would leak and it ran down and rotted everything out. Your battery can be a very lethal source of corrosion and other maladies if you don't keep an eye on it
