I might be missing something, but I'm somehow a little lost.
My 79 LeBaron with tilt steering wheel acts like it should (according to the service manual):
-> Hazard Switch on -> all lights flash (correct)
-> additionally apply brake -> all lights ON (correct for tilt steering according to service manual - continuing flashing lights for non-tilts).
So far, so good.
Now, here in Germany, we have a "technical requirement", that the flasher must continue to flash, even if you apply the brake. Don't even get me started with the discussion which is better....
Anyhow, looking at the wiring diagram for both (tilt and non-tilt, see below), the wiring seems to be exactly the same (wires in diagram are just diferently routed) - except for an additional connector with the tilt steering. And the hazard switch disconnects the brake switch from rear lights in both cases. But the tilt-steering does not disconnect brake switch from directional lights....
Might the wiring diagram be incorrect for the tilt steering?
This sounds like a superfluous discussion , but I'd love to understand before I dismantle the switch (which otherwise operates perfectly for directional an speed control) and adjust wiring to comply with local requirements.
So far, so good.
