FMJ parts or deals thread
greymouser7
31547 off of I-95 near I-10
1979, 2 door Plymouth Caravelle - $3895 (Creston) http://cranbrook.craigslist.ca/cto/4845297566.html
Family owned car (Grandma's), mostly stored inside. 149,500 Km. Well maintained mechanically, interior in great shape - needs a little bit of minor body work. Excellent running order, just drive it away.
preferred contact method: email or text
contact name: Vern
contact by phone: ☎ 604-908-5582
reply by email:
mfqs8-4845297566@sale.craigslist.org
contact name: Vern
reply by email:
Nice Caravelle!
greymouser7
1973 mopar - $3400 (Springtown) Has a demon/70-72SWINGER FRONT CLIP, http://dallas.craigslist.org/ndf/cto/4851777353.html
1973 Dodge Dart sport
318ci with 3 speed auto 904 trans. Dodge demon front clip ford nine inch rear end. It has clean black bucket seats and rear bench clean. Just needs carpet and headliner. New front end work done 100 miles ago. Including ball joints shocks torque arms and bushings all the way. I will send pics of anything on the car upon request because I'd rather you see and hear it in person. If you have and iPhone i can send you videos of me driving it. Also intrested in trading for another vehicle. Let me know what you have. Very intrested in ford f100's
preferred contact method: phone, text, or email
contact name: Jason
contact by phone: ☎ 817 715 1072
reply by email:
n8w4f-4851777353@sale.craigslist.org
greymouser7
MOPAR PART TRADER GUY
preferred contact method: email only
reply by email:
wpzqr-4860123297@sale.craigslist.org
http://dallas.craigslist.org/ftw/pts/4860123297.html
IF YOU SEE THAT I UPDATED MY AD, THAT MEANS I ADDED NEW PICTURES/PARTS OR SOLD SOME. There are several photos, so scroll through them.
Parts wanted for my 1970 B-body & 1971 E-body Mopar:
WANTED: 340 or 440 engine for mid-January1971 Mopar, Engine or Engine Block: If you can read the stamped assembly date that's great otherwise go with the Cast date on the passenger side of block between 9-10-70 and 12-19-70 (100 days)
Can be anywhere from a bare block to a running engine.
Also looking to purchase 440 block or complete engine for a mid-May 1970 care, or with cast date from 1-15-70 to 4-25-70.
WANTED: 4-speed tranny and shifter for 1970 and 1971 Mopar
For the 1970, prefer stamped code between the following numbers pp833 3050 through pp833 3150,
For the 1971, prefer stamped code between the following numbers pp833 3330 through pp833 3430 (100 days).
Will consider all 833 4speeds for parts.
SELL or TRADE: I have 833 4-speed transmissions to get rid of. Here are the dates of mine :June 4th 1965 (short tail A-Body), Oct 9th 1968 (long tailshaft for B-body late 68, early 69), August 72-Dec 74 (long tailshaft dual shifter for B/E body, cant make out the stamp, but it starts with a 4).
TRADE OR SELL:
I need interior panels black for 70-74 Barracuda. Need door panels, rear side panels and back of seat panels.
I will trade my black interior panels for 70-74 challenger (Chrysler OEM panels, Chrysler logos on back). These are the interior rear side panels, also known as rear door panels even though there is no rear door.
HOOD: 1970 Superbee ramcharger hood for N96 option. no accident, never rusted, no cracks in the fiberglass ramcharger shroud, it is all original. Will trade for bulge hood for car that did not have N96 option.
Price 2500 for hood & shroud. May split, but I will hold offers til I get deposits on hood & shroud. Text me what it's worth.
DASH (B-body): roadrunner, Superbee, charger rally A/c metal dash board frame with gauges and Wiring harness.
INTERIOR (E-body): non-a/c Dashpad newly refinished over metal frame. Black console, no cracks, OEM (Chrysler logos on glovebox lid). Interior rear panels and kick panels for challenger.
Brake parts:
Hemi Master cylinder (Large reservoir)
Calipers (slide pin type) - 1 brand new, 2 are used, but not very old and work very good with no leaks.
Hubcaps are from:
Chrysler B-body cars.
Late 60's GMC pickup
For Ranger
Phone me, text me or Email me the CAST DATE, $$PRICE$$., and what's included (bare block/short block/long block/complete with accessories).
(817) Ate Ate zero - 4350
•do NOT contact me with unsolicited services or offers
greymouser7
Have you ever wanted to be the captain of your own battleship?
This one is for that sick Captain Canada Caravan guy: 1972 Chrysler New Yorker 440 70 71 72 73 Dodge Plymouth Mopar - $3500 (McKinney)
http://dallas.craigslist.org/ndf/cto/4850611414.html
contact name: Keith
contact by phone: ☎ 214-548-7538
reply by email:
hrfcx-4850611414@sale.craigslist.org
No calls after 7pm please. May trade for a nice newer car.
Spent a lot of time and money on this one but, she has to go. She has a new master cylinder, new front brake hoses, remaned calipers, turned the brake rotors, new brake pads, new front bearings and seals, new inner and outer tie rod ends, new pitman arm, new idler arm, new sway bar bushings, new tires, new spark plugs, new wires, new cap, new rotor, new fuel pump, new Holley Street Avenger 670cfm carburetor, new double roller timing chain set, new water pump, new fan clutch, new belts, new hoses, remaned alternator, new voltage regulator, new ballast resistor, new control module, had the radiator redone, and I had the fuel tank redone. Also installed a new speedometer cable, aftermarket tach, oil pressure, and water temp gauges. I also installed an aftermarket coolant recovery tank, fixed the bad blower motor switch with a new one. Installed new high and low beam headlights and installed a new brake light switch which still needs to be adjusted. I started the resto, now you finish. I was getting ready to install dual exhuast, get the suspension finished, get the body work and paint done, install new carpet, a new vinyl top installed, and have new headliner installed. I bought this car from the original owner who is a retired school teacher. She owned it for almost 40 years until I bought it in 2011. I also have the original build sheet which was under the back seat. Clear title in my name. Key words mopar hemi 340 426 440 six pak challenger cuda duster plymouth fury monaco polara newport new yorker classic vintage muscle car road runner gtx
YouTube video of her:
https://www.youtube.com/watch?v=VYtH2l87DYU
greymouser7
contact name: Keith
reply by email:
Caravan guy???!!!
You mean CARAVELLE right??
greymouser7
Edlebrock manifold Dodge mopar 440 carb and intake manifold - $100 (Ventura)
reply by email:
qz5rc-4855597127@sale.craigslist.org http://ventura.craigslist.org/pts/4855597127.html
Rv engine motor drivetrain 440 mopar complete running 1980 - $1 (Ventura pick up)
Runs good Has 50,000 Edlebrock intake http://ventura.craigslist.org/pts/4846973176.html
reply by email:
5vd2j-4846973176@sale.craigslist.org
MOPAR CLOSE RATIO 4- SPEED TRANSMISSION WITH HURST COMP SHIFTER - $900 (Santa Paula, CA)
http://ventura.craigslist.org/pts/4849867345.html http://ventura.craigslist.org/pts/4849867345.html
Close ratio Mopar 4 speed transmission with the original Hurst Competition Plus Shifter. All steel B-body with long tail shaft housing. 23 Spline input shaft with flange style output. These are legendary strong made by Warner Gears. This came out of a Sport Fury and has been in my garage about 40 years. Great condition at a great price for your project!
preferred contact method: email or phone
contact name: Harry
contact by phone: ☎ 805-794-9989
reply by email:
nkfs2-4849867345@sale.craigslist.org
Wheel spacers adapters 1.5 (1-1/2) inch Ford Mopar 5x4.5 Race-ready! - $50 (Thousand Oaks)
http://ventura.craigslist.org/pts/4818881663.html reply by email: jzcxp-4818881663@sale.craigslist.org
I had these 1-1/2 inch billet aluminum wheel spacers on my race car for one season. These are STRONG. My car makes over 600 ft-lbs of torque and runs 10's. You should have no problem with these on any application.
These are for 5x4.5 bolt pattern, so they will work on most Fords and Mopars.
greymouser7
Black Powder Coated Mopar Dodge Plymouth 15"x7" Wheels - $200 (Monrovia) http://losangeles.craigslist.org/sgv/pts/4864623141.html
I sold my Dart recently, so I am selling this pair (2) of 15" x 7" rear wheels.
I just had them sandblasted and powdercoated in matt black. They have never been mounted since.
My Dart had a big-bolt pattern A-Body 8-3/4" rearend, so these wheels are BIG bolt pattern (5x4.5").
For Mopar Dodge Plymouth Road Runner, Coronet, Belvedere, Savoy, 330, 440.
I spent over $250 between buying them, blasting and powdercoating, so no low ballers. I will ignore.
Thanks,
Tim
P.S. For another $50, I have a this nice pair of used rear tires. They are in really good condition and have no cracks. They are the perfect size for these wheels and should fit any Mopar wheelwell, as they were on the rear of my Dart and fit perfectly.
contact name: Tim
contact by phone: ☎ 6267167780
reply by email:
xwjhj-4864623141@sale.craigslist.org
greymouser7
Mopar SB Edelbrock Performer RPM intake - $165 (Marietta, GA) http://atlanta.craigslist.org/nat/pts/4820076282.html
Edelbrock Performer RPM intake (7176), super clean - $165
Dual Plane Alum intake, Sq bore - lists new $275 - save yourself over $100
Intake was for the set of Mopar 2.02 X-heads I am also selling on Craigs list.
Will fit 273/318/340/360 Mopar Small Block
Would prefer to be picked up but will ship (Buyer pays shipping)
Payment - Cash, US postal MO or Paypal (includes 3% pp fee).
Shipping from zip 30066
contact name: Greg
contact by phone: ☎ 727-252-6977
reply by email:
bdndf-4820076282@sale.craigslist.org
greymouser7
1976 Mopar 440 engine - $900 (Dawsonville) http://atlanta.craigslist.org/nat/pts/4828039056.html
1976 Mopar 440 ci big block, RV cam, not many miles on rebuild, comes as a long block ( heads, block, intake manifold), came out of a Power Wagon truck that I swapped for a Cummins, ran great when removed, needs refreshing, $900
Also have rebuilt Big Block 727 4x4 auto and 203 case for an extra cost
reply by email:
wr7hj-4828039056@sale.craigslist.org
greymouser7
Mopar Rally Wheels - $325 (Dawsonville) http://atlanta.craigslist.org/nat/pts/4859910484.html
Set of 14" rally wheels that are in excellent shape. They have the large bolt pattern (5-4 1/2"). The center caps are not included, just the wheels, trim rings, and tires. Three of the tires are in nice shape with some tread left and the other is getting bald.
$325 OBO
Call or text 678-410-2132
greymouser7
1971 Plymouth Satellite (Like Roadrunner) Mopar Project - $3250 (Nahunta, Ga) http://atlanta.craigslist.org/sat/cto/4849511634.html
1971 Plymouth Satellite Sebring. Car was parked a little close to a brush fire, and very front of the car was burned. Has a 318 V8 engine (engine runs, needs water pump), with a four barrel cast iron intake and Edelbrock carburetor. Car is very original and complete. Appears drivers side front fender may have been replaced at one time. Car has no over spray on any of the trim or seals to indicate it has been redone anywhere else. Still has a near mint trunk mat. Interior is in really good shape, with the exception of some tears on the drivers side seat bottom, and the dash pad has cracks. Car has power steering and power (drum) brakes. I have another car for parts, and will include the parking lights, headlight harness, and front header panel. Will need a windshield, and a valve body for the A904 transmission. Car is a time capsule, and would be an easy restoration, or would be a great source of parts for your Roadrunner or GTX project. VIN number matches fender tag and door decal. Car is located off highway 301 in Nahunta, Ga. Thank you for looking.
I am working on this car as time allows. As repairs are made, the price will go up accordingly. Hard to find these in decent shape nowadays.
Frank preferred contact method: phone, text, or email
contact name: Frank
contact by phone: ☎ 404-219-9319
reply by email:
v3mt2-4849511634@sale.craigslist.org
greymouser7
1968 plymouth 383 mopar engine. - $500 (athens) CHEAPEST MOPAR V8, RICH'S BACKYARD
http://atlanta.craigslist.org/nat/pts/4850289776.html
I am selling my 1968 plymouth 383 engine that came out of my Fury wagon. This engine was rebuilt by the previous owner several years ago. I upgraded it with an Edelbrock intake and a rebuilt holley 600. I also installed a Pertronix in the distributor and a vacuum advance. The engine runs perfect and very strong with no smoking or oil leaks. I am pulling the engine out to replace it with a new 440. The engine will not include Any of the drive acessories including the alternator, bracket, fan and water pump pulley, radiator hoses and lower crankshaft pulley and carburetor linkages. It will include the starter though.
preferred contact method: text or phone
contact name: Joel
contact by phone: ☎ 678-878-6793
greymouser7
mopar.dodge.plymouth 340 - $2500 (lakeland florida) http://atlanta.craigslist.org/atl/pts/4860044477.html
I have a 1970 340 with about 5000 miles on rebuild.I also have two 727 auto transmission both need to be rebuilt. Date code on side of block is 7/11/69.vin # starts with 0R. O is for 1970 R in build in Windsor Canada.give me a call.thanks for looking
contact name: bobbymopar
contact by phone: ☎ 863-698-6213
reply by email:
xsnqj-4860044477@sale.craigslist.org
greymouser7
360 Mopar Magnum street/strip engine - $2400 (gainesville) http://atlanta.craigslist.org/atl/pts/4798288976.html
360 Mopar engine fresh rebuild with many new parts,Speed pro pistons,rings and bearings,Cloyes double roller timing set,Bullet custom hyd roller camshaft 280/288 .525lift 110 lsa/106icl(largest for stock toque converter,works power brakes),felpro gaskets,melling oil pump,etc. Lopey idle and strong mid range torque and approx 400hp. This engine has 30 minutes run time on the engine test stand to confirm excellent oil pressure,no leaks or other issues. This is a bolt in and go combo that will work in many applications from Rat Rods,Muscle cars or performance pick up trucks.2400.00,add $200.00 for RPM intake and $100 for MP cast aluminum valve covers. Contact me by phone only(NO text)for any details.Shipping or delivery is no problem. Thanks
contact name: james
contact by phone: ☎ 901-674-6178
reply by email:
mb434-4798288976@sale.craigslist.org
