WANTED Front crossmember mounting bushing(pucks)
moparcuda
quebec can
Hi,i look for the se bushings for a dodge diplomat,where i can buy these bushings,,these are the bushings where the crossmember bolt to the frame,,,i checked with rock auto but no chance,,,,thank you
The original style rubber ones are made from unobtainium unless you luck out and find an NOS set. No aftermarket or reproductions. The best bet is to use the poly bushings from Espo Springs n' Things (you have to call to order but they are GREAT there!) or similar place. They're the same ones that a '73 and up B-body uses. They're stiffer than the rubber ones obviously but still have some cushion and noise isolation.
Quality Automotive Suspension Parts For Your Classic Car or Truck
Other option is solid aluminum from Firm Feel
Firmfeel Mopar Suspension and Steering
volare 77
They actually reproduce the rubber ones for 73 up b bodies. There are some on ebay. Not cheap though. Like $300 for the set.
F body Deconstructor Jim
Phoenix, AZ
Wow, I hadn’t seen those rubber bushings in that great of shape in, um, decades.
