Front tag bracket application?
volare 77
Can someone tell me what this tag bracket fits? I googled the number and came up empty. The number on the bracket is 4270325 but many times that part number is no good as most came as a kit.
It’s the tag bracket used for M bodies from 81-89 if I remember correctly.
The earlier brackets had a full plate that mounted to the bumper instead of the two tabs.
I actually have a 77-81 NOS M body plate frame on my 89 Fifth Ave. Was a long awaited score off EvilBay.
It appears in the pic you show it is a little different for the one I posted. Still work? Someone said it fits a 80 F body also? Correct?
Works just fine.
The early 77-81 plate frames (what I have) used a full mounting plate instead of the two little tabs.
Cant comment on if they fit F bodies.
I looked in the parts catalog ('79) everywhere I could think of, including the alphabetical index and there isn't a plate bracket listed for any car. Plate brackets were never installed at the factory. If it was going to a state that required a front plate, the bracket came in a bag in the trunk (along with antenna, wheel covers, etc) and would be installed during the PDI. Probably (a wild guess) there's a dealer accessory catalog that has it listed.
its under license plate bracket. 13-1200 #24 in my 79 parts book but no part number for it. Some other models do have part number listed as do the 80s m's and f's so not sure why that one doesn't.
Works just fine.
It also sticks out further. The 80-89 plate almost touches the bumper. The one you have was meant to be mounted in the middle of the 77-79 bumper and sticks out to clear the point.
Meh, better than zip ties.
I mentioned this on A&V. The p/n stamped in the bracket won't show up in a catalog. The bracket, inserts, screws and any other mounting hardware, along with instructions came in a plastic bag, in the trunk of the car or ordered by the parts dept, and the package would have a p/n for the kit.
Mikes5thAve, NOW I see it in the catalog. Never thought to look in the bumper section, which sounds obvious to me now, lol!
It's funny how those books work that way. I don't think it was pictured either which doesn't help.
