Honestly, if it was my car I would buy a brass float and clean the old one up. The repro replacements are never as accurate.
I almost agree with that. If his fuel gauge works fine, then yea, fix the float, replace the fuel sock, and keep going (you can get new floats and socks aftermarket).
If his gas gauge was not working, then I don’t have a good answer to give
Nice and shiny vs. his old one.
BTW, most Chrysler fuel gauges made in this time frame, didn’t have very accurate fuel gauges. It is as if the gauge registers only the last 4/5ths of the tank – with the first 1/5th not even being registered (IE: fuel gage is on Full tank for about 1/5th of the tank, then it shows 3/4th tank when take is actually at 3/5ths, and so forth).
Almost always, then a fuel sender that says tank is empty - the tank is indeed empty. I would rather have the empty part of sender work and be accurate, than the full aspect of the sender.
Actually I want both to be accurate, but not devised of a way to get both to work correctly without major re-wiring.
The cost and time spent vs. benefit gained is just not there, for me.
Also those aftermarket lock rings are outright dangerous. They are flimsy at best.
Reuse your old lock ring unless it is mangled beyond reuse.
The
new seal should work fine. Install the seal dry and without any other sealant.
