Well, GOOD NEWS is it goes like RAPED APE. Any thoughts on grabbing the choke 12 volts + off the unused ballast post. That is, if I had a 5 wire box, it would be used, but I'm using a 4 wire chrome box. The directions from Edelbrock state not to connect to the coil. The other post is the Positive + to the coil. On the other side of the ballast - the ignition side is tied together. Is the 5 ohms enough of a separation from the coil? Or should I just grab a fused source under the dash? This is a different ballast from above. This is the one on the firewall.
Second minor issue: Trans link bar. I cannot for the life of me get it set up not to bind. I think the bar was bent by the previous owner of the motor and what it was in. According to him- E body cuda.
