Ignition
Mn mopar
Milaca, minnesota
Help i am not getting power to my ignition coil and cant find where the wires go or a diagram if someone could help that would be awesome, car is a 1980 dodge mirada thanks in advance!
Mn mopar
Milaca, minnesota
Ok update, i have put brand new of the following, spark plugs wires cap rotor ignition coil balaster regulator, still no spark what else could it be?
M_Body_Coupe
Windsor, ON, Canada
Here are the FSM scans I made for the non-LeanBurn ignition setup. These should walk you through the troubleshooting if you have that older style ECU setup.
M_Body_Coupe
Windsor, ON, Canada
Omg your a life saver lol thank you
Thanks...but...I'm scratching my head a bit...the pics I uploaded were actually much bigger (so easier to read, more detail)...I see the stuff in the thread as having been sized down...not quite sure if there is a way to get at the originals as I'm not all that familiar with this particular forum software.
