Leaf springs and shocks. 87 5th ave
Lord Alvin
Nashville, TN
I need new leaf springs for my "87 5th ave. Any advice on where to find them for a reasonable price? Also, what type of shocks are you using? I prefer Bilstein and I found them at Firmfeel, but it's $400 for a set. Too much for me. Thanks again for all of the help I have received here. I'm really loving the car.
lowbudget
Vernal Utah
I'm running KYB Gas-Adjust also. I scored them close out at rock auto, dirt cheap. 2 are white and 2 are black, but if you are close enough to notice, you are too close to my car! They are great shocks. I need to go grab a rear cop car sway bar and maybe a front depending on the diameter of mine from a buddy.
greymouser7
31547 off of I-95 near I-10
Two (2) Mopar Performance Competition Leaf Spring 3690460 Price:US $245.94 Summit Racing Part Number: DCC-3690460(2)
Mopar Performance 3690460 Racing Spring, Rear Leaf, Super Stock, Right Side, 3,600 lbs., Mopar, Each
Bushings Included
Yes
For Street Use
No
Front Leaf Spring Bushings Included
Yes
Leaf Spring Style
Chrysler-style
Maximum Recommended Vehicle Weight (lbs)
3,600 lbs.
Notes
Passenger side Super Stock spring for use in 3,600 lb. automatic transmission cars. The front spring hanger must be replaced on B, E, F, J and M-body cars, A-body cars do not require the new front hanger, B-body cars require offset rear shackles. Spring has 6 leaves, 20 in. front segment with 1 clamp, 36 in. rear segment with 1 clamp, 56 in. overall length. The bottom 2 half leafs go toward the front of the car.
Progressive Rate Spring
No
Quantity
Quantity of 2
Spring Finish
Black
Spring Position
Right rear
Spring Type
Leaf
http://www.ebay.com/itm/331456229892?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
80 Aspen RT
Kansas
Be aware, and correct me if I'm wrong, but if you put the super stock springs on its going to raise the back of your car quite a bit.
I detailed and painted mine (the KYB's) Eastwood Underhood Black. They were bright white out of the box.
I'd not suggest Super Stock springs. As mentioned, the car will sit too high and will ride like a lumber wagon (IMO). With my stock rate (new) rear springs, 4 leaf with round front bushing, it rides pretty darn stiff. Not harsh, just firm.
