ChryslerCruiser
Last summer I replaced the lower radiator hose, and cleaned the water pump inlet, because the lower hose was looking really frail.
Now I have a very very slow leak at that spot. It might almost be too much to call it a leak, but I can see that it has leaked just enough to see that it was not 'coolant tight" and dried in place.
Is it a faulty hose clamp? I might have had it ever so slightly not perpendicular to the direction of the hose...
Water pump inlet corrosion? (there was some white corrosion to clean off after getting the old hose out, as I remember I cleaned the neck up with steel wool before installing the new hose)
What are your thoughts, or am I just being OCD about this?
