m1 mopar intake
tim berry
boston area
anyone modify a mopar m1 intake to use the ac compressor that came stock. what needs to be done or alternative intakes or mods .thanks just getting ready for spring and I want to run my ac
jasperjacko
I used a performer on my 360. had to grind down one of the nipple outlets so the compressor would sit straight. Most intakes have the thermostat location in the center and it needs to be more on the driver side to clear the a/c
tim berry
boston area
Thanks Troy do you have any photos and how do you like it
jasperjacko
Modoba thread has eng. pics. Intake is done by 5500 rpm, match your cam
tim berry
boston area
thanks troy I wanted to use what I have. I have messed with the brackets and came close to making it work but without a welder it was not possible so the stock manifold went back on
,it's ok but would like to lighten the load a little and shed some weight .
