Modoba
jasperjacko
Started installing new Dougs 453 headers today. I'll let you all know how they fit.
jasperjacko
Headers are in. plenty of room. One issue though is that I had to slightly move the factory tranny lines for clearance. This involved bending the lines and modifying the bracket that holds them to the bell housing. Not a big deal, but for what these cost, I shouldn't have to do that. Another thing worth mentioning.... Looks to be plenty of room for the 904 and 727. I have to re-do the exhaust because it won't fit. Much easier spark plug access, and more clearance to the brake booster. You must use the mini mopar starter which I already had. Easy access to all the header bolts. I could get a socket or box end wrench on each one, didn't have to use the open end like my old headers. I will post pics tomorrow p.m. I think these are worth the money. They give me about 1.5-2" ground clearance over the old ones.
BHA43
Could you measure from the center line of the ex ports to the bottom of the headers?
jasperjacko
dougs headers
some pics and measurements. The distance from exhaust centerline to lowest part of header is 16"
jasperjacko
Some may remember when I started this thread, that I had tacked up a stainless y pipe for the exhaust. 2.5 into 3". I've been running an older used exhaust with turbos that dumped in front of the axle. That's all gone now and I had to cut up the y pipe again to fit with the new headers. I was going to use a tranverse muffler behind the gas tank, but have decided to run a single 3" flowmaster delta 50 muffler with 3" stainless tailpipe out the back. I have the tailpipe tacked together and will post pics soon and some video when its all installed.
jasperjacko
Exhaust is in, but have to take it to a shop to weld the tailpipe to the muffler. Sounds Great, quieter inside. May be down on power though. I'm going to put a pressure gauge nipple in the y collector to check for excessive back pressure. If the pressure is good, I'll have to work on re-tuning the carb.
I could only get the 1st 22 seconds of the video to play ("Fast, reliable Frontier DSL",,,,,,,excuse me while I'm, bent over laughing..) BUT what did play, sounds excellent!:icon_thumright:
jasperjacko
Did a pressure test on the exhaust, and just as I thought, too much back pressure at WOT 5500 rpm measure 3.5 psi. Guess my "flowmaster is not a master of flow.lol. The tweaking continues.....
tim berry
boston area
troy sounds realy nice but I have a question ,at wot what would be acceptable 0 psi?
jasperjacko
I read in a mopar muscle article that 0-2 is considered a free flowing exhaust. It hit about 2 psi at 4000 rpm and keeps climbing. It's enough that I felt it right away, and the numbers all agree with my first impressions. It has a harder time accelerating after 4500 rpm. Before it would climb to 6000 if I wanted to with no trouble. I even consulted with Flowmaster tech. on my proposed set-up, and he said the delta 50 would be perfect.
jasperjacko
Thanks. The 14.3 was it's first run. Best so far is 13.7 @ 99.6 mph
